• Adaptable Plumbing - Online Store
Stiebel Eltron SimpleX Instantaneous 3 Phase Water Heater
Store/Perth Hot Water Systems - Fully Installed/Electric Instantaneous Hot Water - Fully Installed
AU$930.00
The STIEBEL ELTRON SimpleX instantaneous hot water unit was developed for the Western Australian 3 phase electric instantaneous water heater replacement market.
Water heaters can sometimes break down without warning, leaving us in the lurch with no more hot water. Hot water is a luxury none of us want to live without for very long, and the Stiebel Eltron SimpleX instantaneous hot water system makes replacing hot water units an easy, quick and stress-free process. The Stiebel Eltron SimpleX hot water unit is suitable as a replacement hot water system ion one bathroom houses, as well as in factories and shops throughout Western Australia.
It offers silent water flow, energy efficiency and is ideal for replacing faulty and outdated 3 phase electric instantaneous water heaters. The size of the SimpleX hot water unit allows it to be installed virtually anywhere an existing 3 phase heater is located, with identical dimensions.
When replacing hot water units its always a good idea to upgrade on your old system. The SimpleX instantaneous hot water unit includes various features which save money, energy and water.
If you find yourself suddenly with no more hot water, the SimpleX is the simple, and smart, option for replacing your old system.
SimpleX Water Heaters:
  • No pressure relief valve required
  • Silent water flow
  • Uses existing plumbing, ideal as a replacement hot water system
  • Watermark approved
  • Ideal for 1 bathroom dwellings
  • 2 Year warranty – domestic
  • In-built water saving device
  • Hydraulic control
  • 7.5 Litres per minute at 25 degrees Celsius rise
  • IP24 Rating
Display prices in:AUD
© Adaptable Plumbing - Online Store Report abuse
