• Adaptable Plumbing - Online Store
Wilson Super X 3 Phase Water Heater
Store/Perth Hot Water Systems - Fully Installed/Electric Instantaneous Hot Water - Fully Installed
AU$855.00
SuperX™
INSTANTANEOUS ELECTRIC WATER HEATER
The Wilson SuperX is a mains pressure three phase electric instantaneous hot water heater. The Wilson SuperX has no storage and is energy efficient as it only heats water as required and will continually heat as water passes over the elements. The unit does not require a safetray or water saving devices.
The Wilson SuperX can be installed virtually anywhere and will supply enough hot water for small domestic dwellings, shops or factory amenities.
Energy Efficient
Standard Replacement
Pressure Relief Valve
18amp 3 Phase
2-year Domestic and Commercial Warranty*
Quiet Operation
Watermark Approved
Australian Made
Display prices in:AUD
© Adaptable Plumbing - Online Store Report abuse
